  3. AMS library for Cadence layout
  • Views 15240
ezhanga
ezhanga over 10 years ago
As shown in the pictures below, when I use a device in the AMS library, e.g, nmos4, the resulting shape on the layout window is only a rectangle whose layers are all hidden. However, if I create a rectangle on MET1 or on Poly1, they are visible. (shown in the second figure)
Anybody know how to turn on the layers inside the nmos4 device?
  • ColinSutlieff
    ColinSutlieff over 10 years ago
    Junri,
    You have the display settings set for top-level only.
    Simply press <shift>f to display all the levels of hierarchy. Or if that doesn't work, click options->display and set the stop level (at bottom of form) to a large number (31 perhaps).
    Colin
