  3. Transient simulation output files
  • Views 17123
Gurunath Kadam
Gurunath Kadam over 10 years ago
Hi all,
I have following code:
<code>
simulator lang = spectre
parameters
+ v_vdd = 0.990
xringoinv (ven rn_i ro_o vdd vss) ringosc_sim_sub
ven (ven 0) vsource type=dc dc=0.990
vdd (vdd 0) vsource type=pulse val0=0 val1=v_vdd delay=2n rise=100p fall=100p width=50m period=100m
vss (vss 0) vsource type=dc dc=+0.0 mag=0.0 phase=0.0
vddsweep sweep param=v_vdd start=0.85 stop=1.15 step=0.05{
trsweep tran step=0.01n stop=10n
export freq=oceanEval("1/delay(?wf1 v(\"ro_o\") ?value1 value(v(\"vdd\") 10n)/2 ?edge1 'rising ?nth1 3 ?wf2 v(\"ro_o\") ?value2 value(v(\"vdd\") 10n)/2 ?edge2 'rising ?nth2 4)")
//some simulatorOptions
Spectre options rawfmt=psfascii rawfile="ringo_tb.psf" measoutput=detail
//some circuit
//some lib
</code>
I don't know how to write the Freq parameters in each case in an output file. Something like in two columns VDD freq.
Thank you
  • Gurunath Kadam
    Okay, so after going through Spectre manual more than once I realized there is probably no way to do this in Spectre stand alone, but I need to use SpectreMDL. I was already using Ocean equations for measurements!
  • Gurunath Kadam
    I have now a *.scs file and another *.mdl file.
    As I check I ran only spectre *.scs file which runs fine.
    My *.mdl file is as follows:
    alias measurement runtran {
    export real deltaxOut
    run trsweep
    deltaxOut = deltax( sig1=V(ro_o), sig2=V(ro_o), dir1=’rise, \
    thresh1 = 0.45, dir2=’rise, thresh2=0.45, start1=4n, start2=4n )
    run runtran
    When I run:
    spectremdl -b *.mdl -d *.scs
    My output files (*.measure, *.mt0) do not have any measurements reported in them. I don't know what is wrong.
    Any help?
    Thanks.
