  3. Get transistor region automatically printed or plotted
  • Views 14812
olalivier
olalivier over 10 years ago
Hi there,
I would like to print and/or plot the region a transistor is working in without having to do it by hand with
print -> DC operating points
Instead, I'd like to set it in the result I want to be automatically plotted
add expression -> op -> select an instance -> op parameters...
unfortunately, when I use the above method, the region parameter does not appear  in OP parameters...
I use virtuoso 6.1.6 with design kit ams 018  version 411
thank you very much for your help.
Olivier
    You may need to contact AMS.
