  3. interpolation for xmin calculation
  • Views 16869
RobinCommander
RobinCommander over 10 years ago
As an addition to phase margin & gain margin in some AC open loop simulations I have been also been calculating the vector margin which can be useful.
I calculate it thus:
stb_x = xmin((abs((v("/Ampout" ?result "ac") - complex(-1.0 0.0)))**2))
stb_dB = (- db20(value(v("/Ampout" ?result "ac") stb_x)))
To get more accurate results I need to add more points/decade which can slow things down in swept simulations, I assume this is because only the data points are used in the xmin calculation. I was wondering if interpolation could somehow be used in the xmin calculation so I can speed up the simulations. Or maybe there is some other way of doing this calculation.
Robin
    Robin,
    I don't think it's a case of getting xmin to interpolate - the minimum y value must inherently be a point that's in the original waveform unless you do some kind of spline fit of the curve. However, I think that probably you want to find the closest point on the Nyquist plot to -1,0 - and that may not be at a point. I'll have a think about that.
    It wasn't obvious to me why you have the **2 (squared) term in your expression?
    Also, assuming that an interpolated x-value could be found, I think you'd want to do value(db20(...) rather than db20(value(...)) because that way it would linearly interpolate something in db which I think would probably be more appropriate (even then it's not quite right because you really want to linearly interpolate on a log-log curve, I guess. Right now it doesn't matter because the x point you're using value() at is one of the original points, and so there's no interpolation in the value() either.
    Anyway, I'll have a think about possibiities of calculating this vector margin. Potentially it could be a good enhancement for spectre's stb analysis to output this figure of merit too.
  • RobinCommander
    Andrew,
    I didn't think there would be an easy answer for the interpolation, but thought it worth trying here.
    I think I got the expressions for evaluating the vector margin from here:
    www.circuitdesign.info/blog/2012/02/creating-a-nyquist-plot-with-cadence
    I didn't check if the **2 was useful, so maybe it isn't needed.
    Sometimes when sweeping a parameter in ac analysis I found the phase margin would improve but gain margin reduce so I started looking for another measure of stability for a third opinion.
    Also phase & gain margins are measured at single points which might miss any peaking between these two measurement points.
    Robin
  • RobinCommander
    p.s.
    I think the formula I gave above isn't really the Vector Margin as it measures the distance
    to the origin not to (-1,0).
    I think it should be:
    VectorMargin = abs(value((v("/Ampout" ?result "ac") - complex(-1.0 0.0)) stb_x))
    I've also seen this called stability margin. Recommended values I've seen are >= 0.33 to 0.5.
    A related measure is Vector Gain Margin which is somewhat similar to gain margin.
    VectorGainMargin_dB = db20(1 - abs(value((v("/Ampout" ?result "ac") - complex(-1.0 0.0)) stb_x)))
    You can also calculate Vector Phase Margin, although I'm not sure how useful that is:
    VectorPhaseMargin = value(phaseDeg(v("/Ampout" ?result "ac")) stb_x)
    Robin
