  3. Plotting sweep results from RMB->Main Form in ADEXL
  • Views 2401
Michele Ancis
Michele Ancis over 10 years ago
Hi all,
I am a little puzzled because I cannot select signals on the fly with the interactive method, after an ADEXL parameter sweep simulation,
by right mouse button click on any Results Tab cell, and have them plotted for all swept values at once.
I distinctly remember being able to do this, so I am wondering whether this feature is not available anymore, or through other mechanisms perhaps?
Scenario
You run an ADE XL test bench simulation, while sweeping a variable in your "Global Variables" list.
In the Results Tab, a table appears after succesful simulation, with a Column Header (Point, Test, Output, Nominal, Spec, Weight...)
The Point is a unique integer number, your "design point", for each of value of your swept parameter.
A grey row identifies the design point more verbosely (?) : Parameters: your_param=step_value
Between two grey rows appear the Outputs you decided to issue, waves, numbers, whatever.
Goal
You forgot to plot the voltage at that particular node, and want to quickly check it across all swept parameters. Let's say it is a transient simulation where you swept a supply parameter, and you want to see the effect on the reached voltage at some node X.
I distinctly remember that - in previous versions - it was just a matter of RMB->Direct Plot-> Main Form. The only thing is that you had to click in a specific place, otherwise the form would output the result of the specific design point area you RMB clicked to begin with.
Not sure, but I think it was if you clicked in the "Output" column, instead of the "Nominal" one, you had this behaviour.
Now, no matter where I RMB click, I always get only the single design point.
I am on IC6.1.6.500.10
Any hints?
Michele
P.S. This functionality is the same as RMB in the output pane and choosing between (Plot All, Plot, Plot Across Corners,...)
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    I am using IC6.1.6.500.13 and every column except Point (where Direct Plot is not available) and Nominal (which plots a single design point) will give the behavior you are looking for.
  • Frank Wiedmann
    I just did a few more quick tests and found out that the version you are using seems to be the only one that has this problem. In the list of fixed CCRs for IC6.1.6.500.11, I found the following line which seems to refer to this problem:
    1377743 Direct Plot does not plot all corners in IC6.1.6 ISR10
  • Michele Ancis
    Thanks for checking this out Frank! I've always known I'm lucky :-)
