  3. ADE could not see the voltage signals
  • Views 16006
Ctree
Ctree over 10 years ago
Hey, everyone,
right now, I make s current mirror simulation with the mosfet. my problem is, I could only see the current transient signals, I could not observe the voltage signals ,for example the Vgs, etc. I do not know why, sb can help me?
Thanks very much!
Tony Zhang
    Tony,
    Can you show the bottom part of the input.scs (all the options, analyses, and save statements etc - everything to the end of the file - no need for the circuit part)?
    My guess is that you're not saving the voltages, but seeing the netlist would confirm that theory.
  • Ctree
    Hey, Andrew, the bottom part of the input.csc :'simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
    tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
    dochecklimit=yes checklimitdest=both devcheck_stat=no
    tran tran stop=50u write="spectre.ic" writefinal="spectre.fc" \
    relref=alllocal annotate=status maxiters=5
    save Vgs M0:1 M1:1 M5:1 M4:2 M3:1 M6:1 net16 net14
    saveOptions options save=none currents=selected subcktprobelvl=2 \
    useprobes=no saveahdlvars=selected'
    You have save=none which means that it will not save any voltages. You want save=selected so that it saves the "selected" nets (i.e. Vgs, net16 and net14).
  • Ctree
    Yes, I would like to save it. Regards, Tony Zhang
    That's fairly obvious - I just was telling you that you need to set save to "selected". If it's set to "none", the voltages you've requested won't get saved. This is on the Outputs->Save All form in ADE.
