  3. Custom Calculator Function with Parametric sweeps
  • Views 20013
Eugene201
Eugene201 over 10 years ago
I'm trying to create a calculator function to measure the sample period of a sample and hold circuit. I was able to create a function which achieves what I want and posted the code below. However, this function only works for a single run simulation and returns the correct value. When the same function is applied to a swept variable or optimization simulation it returns an eval error. This is because the waves being passed to the function are family_waves. I have tried to use the fam* functions to separate the simulation results without success. The simulator calculates the results for each individual point in the simulation which for a family of waves would require the presence of a variable identifying the particular simulation but I don't know how to get that. I have not been able to find documentation regarding the difference of how variables are passed in single vs optimization or sweep runs. Any help is greatly appreciated.
I'm running the simulation using ADE-GXL transient analysis with sweeping global variables.
Version of Cadence is IC6.1.6-64b.500.9
(procedure (ezSampleRipple waveClk waveSig)
(let (sweepVal waveTemp1 yList timeList len outNum waveClk1 waveSig1
(maxTemp 0) (minTemp 0) (DiffTemp 0) (diffSum 0)
;;;;;attempted solution for parametric sweep
if(famIsFamily(waveClk)
waveClk = famValue(waveClk famGetSweepValues(waveClk));
);end if
if(famIsFamily(waveSig)
waveSig = famValue(waveSig famGetSweepValues(waveSig))
);end if
WaveTemp1 = cross(waveClk 0 0 "falling" t "time")
yList = drGetWaveformYVec(WaveTemp1)
setq(len (drVectorLength yList))
for(i 0 (sub1 len)
(setq timeList (tconc timeList (drGetElem yList i)))
);end for
foreach(crossTime car(timeList)
maxTemp = ymax(sample(waveSig (crossTime+5p) (crossTime+45p) "linear" 0.1p))
minTemp = ymin(sample(waveSig (crossTime+5p) (crossTime+45p) "linear" 0.1p))
diffTemp = maxTemp-minTemp
diffSum = diffSum + diffTemp
);foreach
outNum = diffSum / len
) ; let
) ; procedure
Thank you in advance,
Eugene
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    Have you tried using the famEval() function (see http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:TechPubDocs;src=pubs;q=/vivaxlskill/vivaxlskill6.1.6/chap4.html#1033660)?
  • Eugene201
    Hi Frank,
    Thank you for the quick reply. I did not see this function in skartistref and didn't originally try it. I think this function is exactly what I'm looking for but I'm having trouble implementing it. I get the sweep name and sweep value using the fam functions provided. However, when running the function fails and says error evaluating (VT("/net014")-VT("/net015")). I have included the cut-out of how to isolate a single wave but it doesn't work. Please let me know if I'm using this wrong.
    sweepVal = famGetSweepValues(waveClk)
    sweepName = famGetSweepName(waveClk)
    sweepVal=car(sweepVal)
    waveClk = famEval((VT("/net014")-VT("/net015")) sweepName sweepValue)
    );end if
    waveSig = famEval((VT("/vinp")-VT("/vinn")) sweepName sweepValue)
    );end if
    Thank you,
    Eugene
  • Frank Wiedmann
    Have you tried using the famEval() function without the optional arguments?
  • Eugene201
    Hi Frank,
    I have tried the famEval() function without the optional arguments. However, the famEval without arguments returns the same family of waves as the input(example1 given below). Would it be possible for you to show a simple example of how to use famEval to have the function evaluate during Single Run, Sweep Run, and Optimization Run? I have included a simple example of a code that evaluates in a single run but fails in sweep and optimization (Example2).
    Example1 of famEval() use
    wave=VT("/vin")
    wave_single=famEval(wave)
    returns --> wave_single = wave
    Example2: Simple calc function
    (procedure (genExample2 waveIn)
    (let (maxTemp)
    maxTemp = ymax(waveIn)
    ) ; let
    ) ; procedure
    Thank you,
    Eugene
  • Eugene201
    Hi Frank,
    I think the problem is not the issue of having family wave passed to the function but the definition of the function itself. When I hit re-evaluate in ADE GXL it populates the answers without a problem. However, when I run a sweep or optimization it sees the function as undefined. Is there a way to define the function so that it can be used during the sweep as well?
    Thank you,
    Eugene
  • Eugene201
    Eugene201 said:
    Hi Frank,
    Thank you,
    Eugene
    Hi Frank,
    I have found the solution to my problem. It was not the problem of dealing with wave families but rather that the ICRP didn't know my function when running the sweep. The solution 11821730 on the support website solved my problem.
    Thank you for all your time and help. It led me in the right direction.
    Eugene
