  3. Found a bug of system function $fwrite in verilog A
  • Views 16794
Biasing
Biasing over 10 years ago
When I was using $fwrite to save the data generated during simulation, there are some unexpected 0s in the txt file. But in the Virtuoso Visualization tool, there are no any 0s.
The code is $fwrite(fp,"%f \n",Newout)
Then I write a test function, which is
// VerilogA for ADC, VerilogBugTest, veriloga
`include "constants.vams"
`include "disciplines.vams"
module VerilogBugTest(clk,Dout);
input clk;
output Dout;
voltage clk;
voltage Dout;
real Data;
integer fp;
analog begin
      @(initial_step) begin
            Data = 0;
            fp = $fopen("/users/mingliang/tsmcoa018BCD/ADC_Idealblock/VerilogABugTest.txt","a");
      end
      @(cross(V(clk)-0.9,+1)) begin
            Data = Data + 1;
            $fwrite(fp,"%f \n",Data);
      end
      V(Dout)   <+ transition(Data,0.5p,0.5p);
end
endmodule
The result shown in the Virtuoso Visualization tool is
I also exported the data written by the system function $fwrite and plot it in the Matlab.
There are two 0s !.
Is these a bug of Verilog A or Is there something wrong in my verilog A code?
Best regards,
Biasing
    Did you by any chance run the simulation three times? You're opening the file with "a" as the second argument to $fopen, which will append onto the existing contents of the file. So each time you run the simulation it will append the data onto the end of the file and start at 0 at each point.
    Other than that, I don't see anything wrong with the file and the only way I could reproduce your problem was to run the simulation three times. If you don't use "a" as the second argument to $fopen but use "w" instead, then it creates the file from scratch each time.
  • Biasing
    Thank you very much! I have solved that. The problem is exactly same to what you said.
    Best regards,
    Biasing
