  3. P-Cell installation (FreePDK45)
  • Views 18639
ahmed589
ahmed589 over 10 years ago
Hi All,
I am trying to make this instructions work (http://www.eda.ncsu.edu/wiki/FreePDK45:Using_P-Cells)
I am having some difficulties along the way, it would be of great help if you could point me to the right direction!
I have tried to follow the instructions in the web site. I did not quite understood the step 2 and 3.
"add the Python path to the first line of each script in this directory" - I amnot sure which python path is this. Is this $PDK_DIR/ncsu_basekit/gentech/sshaft/bin ? And after trying a while, it seemed have created a "bin" folder : $PDK_DIR/ncsu_basekit/gentech/bin and copied all *.py files here.
While updating the icoa_setup.csh, I have found that, I also needed to source the setup.csh file as well, otherwise the NCSU_TechLib_FreePDK45 or NCSU_Devices_FreePDK45 library do not load in virtuoso.
Finally, when I run the command gentech.py -log gen.log from $PDK_DIR/ncsu_basekit/gentech, I am getting the following error:
/home/class/ahmed589/NCSU-FreePDK45-1.4/FreePDK45/ncsu_basekit/gentech/sshaft/bin/gentech.py: Permission denied
Probably because: the first line of the gentech.py is not an executable file, rather a folder
(#!/home/class/ahmed589/NCSU-FreePDK45-1.4/FreePDK45/ncsu_basekit/gentech/sshaft/src/py/)
if the line is changed to
#!/home/class/ahmed589/NCSU-FreePDK45-1.4/FreePDK45/ncsu_basekit/gentech/sshaft/src/py/gentech.py
then the following error message is found:
import: Command not found.
Badly placed ()'s.
May be the following info would be helpful:
Operating system: Linux 2.6.32-573.3.1.el6.x86_64
virtuoso version 6.1.5
oaGetVersion : 22.41.004
Pycell studio version : 2014.09-L4 of PyCell Studio.
PyCell Studio build with Python version: 2.6.2 (r262:71600, Apr 7 2011, 14:30:04)
[GCC 4.4.3]
I would be eagerly waiting for your reply. Thanks in advance for your time !
  • Quek
    Quek over 10 years ago
    Hi Ibrahim
    Actually it is not advisable to use python cells in Virtuoso platform because it is not fully supported. It would be better if you download Cadence generic pdk 45nm (gpdk45) from COS website. It contains SKILL pcells which can be used for practice purposes.
    Perhaps you can try changing the 1st line to "#!/bin/python" to see if it works.
    Best regards
    Quek
