  3. disable temperature dependence of an element/instance
  • Views 1147
vamshiky
vamshiky over 10 years ago
Is there any way to disable to temperature dependence of a block analogous to noise contribution ON/OFF ?
I have a spec for temperature drift at the output of my design which has multiple stages/subblocks. Hoping this would help me debugging which stage contributes to most of the spec.
Vamshi
    Hi Vamshi,
    You can use the MTS options in ADE XL to explicitly set the temp on particular cells or instances - so that might be a way of doing what you want. It doesn't disable the temperature dependence, but if it overrides the temperature that would have the same effect, I think.
