  3. Library Technology Manager
  • Views 14923
Arafat01
Arafat01 over 10 years ago
Hey,
I am trying to open the Library Tech Manager.
When I do that the ciw says *Error* eval: unbound variable - ciwvHelpMenu.
I short for some reason it seems locked.
Can anyone suggest something?
    I don't know what "I short for some reason it seems locked" means, but I suspect you have a local ciw.menus file which is overriding the standard menus.
    In the UNIX terminal, type:
    cdswhich -all menus
    and then in each of the directories found (if any) look for a file called ciw.menus. If found, move it aside.
    The standard ciw.menus file is found in <ICinstDir>/tools/dfII/etc/tools/menus/ciw.menus .
    I just did some searching and found this solution. This essentially says the same as above - looking for menus directories in the working directory and in the home directory (~). In that case the issue arose in IC616 ISR11 (IC6.1.6.500.11) and similar ICADV12.X vintages because of using a ciw.menus file from an older release.
