  3. noise contribution in a calculator expression
  • Views 20013
vamshiky
vamshiky over 10 years ago
I am running pnoise and seeing noise contributions from each block with the help of print noise summary .
Is it possible to add the block level noise contributions in a calculator expression so that I view it across all PVT corners easily in ADEXL.
Its a bit painful to print noise summary for every corner and observe the same.
I was able to  get device noises  contribution into calculator expressions  from result browser, but couldnt do block level .
Vamshi
    Vamshi,
    Please see the discussion in this recent thread:
    http://community.cadence.com/cadence_technology_forums/f/33/p/29528/1343434#1343434
  • vamshiky
    Thanks for the quick reply and solution Andrew, that was quite helpful. However I was not able to use it ADEXL properly as it expects that noiseSummary is not available while ADEXL tries to evaluate all other variables/expressions.
  • vamshiky
    I have tried creating all noisesummaries by opening print noise forms across all corners and reevaluated ADEXL expressions. but they seem to fail in evaluation.
    I pointed out in the other thread that this doesn't happen automatically at the end of simulation, so it's not really a viable approach for ADE XL. It would need an enhancement, and for that you should contact customer support. Frank filed a CCR for this capability - mentioned in the other thread.
  • vamshiky
    ok thank you.
    Also is there any env variable to set the defaults in that print noise summary window for having to set hierrachy=1, integ noise, bandwitdh limits etc?
    Everytime when I run a new sim that window loses the history(recent settings used) and goes to some defaults.
    Vamshi
    Vamshi,
    I filed an enhancement request for this some time ago, CCR 753123. It hasn't been implemented yet, so if you want this, you should contact customer support and request that a duplicate be filed to increase the likelihood that it is implemented sooner.
