  3. High current in Id-Vg simulation
  • Views 15306
mahaque
mahaque over 10 years ago
I am trying to simulate a testbench having just a MOSFET and voltage sources and ground. But the drain current seems to be quite higher than expected. What might be the reason of it and what should I do to solve this?
Thanks in advance!
    Nobody will be able to guess what your problem is without more information. Please read the forum guidelines and provide some appropriate extra data.
  • mahaque
    I have simulated a SiC power MOSFET is Saber. Now I am trying to simulate the same power MOSFET using spectre using the same testbench including the mosfet, gate voltage source(from 0-14 V), drain voltage source(20V) and ground. Both the simulations should provide the same outputs since I have used the same parameter values in both Saber and Spectre.But Spectre shows a higher current in Id-Vg curve. So I am trying to figure out what I might have been missing in the simulation. Please feel free to ask if you need any further information to help me out.
    I suggest you contact customer support who can guide you through the detail we need - seeing the models, netlist and results are likely to be important here, and I doubt you can do that in a public forum - unless the model is your own to share.
