  3. ADE-XL
  • Views 15443
ADE-XL
analogy
analogy over 10 years ago
Somehow I cannot plot my output in ADE-XL.This is what I see in my CIW :
*WARNING* (reader): illegal character '%' ignored at line 1 of string "..._noise_time:1" ?history %"
*Error* AbstractMethod: Needs to be implemented by the appropriate sub-class
    What is the expression you're trying to plot?
  • analogy
    Surprisingly I have disabled all expressions.
    How can you plot the noise outputs if you've disabled all expressions? Please explain clearly what steps you're doing (and the version you're using) - including what kind of noise analysis setup. Otherwise there is little chance of being able to diagnose this. Or maybe going to customer support would be best. Andrew
  • analogy
    I figured out where the problem was.
    My ADE-XL state was saved as PSS+PNoise-Accurate=Real-IndefinitePole
    Seems like Spectre (or APS) doesn't like the fact that my ADE-XL state has "+" operator.When I renamed this state to PNoise , it worked without errors.
    Andrew, what are the acceptable characters one can use for State names ?
    There's not really a thing called an "ADE XL state" - or at least that's ambiguous. So are you referring to:
    1. The name of the ADE XL view?
    2. The name of a Setup State within ADE XL?
    3. The name of a test within ADE XL?
    I think this is a bug, regardless of where it is, because illegal characters should either be disallowed or should be mapped if they cause problems. There is some support by an env var to do mapping of some characters within the ADE XL view itself (this for strange historical reasons is not enabled by default), but that wouldn't help if this is the name of the ADE XL view itself.
    Personally I would stick to alphanumeric characters and underscore, and not begin with a number. That's generally a safe bet with most applications. However, as I said, we should be able to handle this regardless...
