  3. Embeding output expressions in graphs
  • Views 14795
AlbertoGS
AlbertoGS over 10 years ago
I would like to embed some output expressions in the output graphs of my simulations. See example:
Unfortunately I am unable to figure out how to do so (which menu option should be used). Could someone help me with it?
Many thanks,
bertgoz
    You can do this with Marker->Create Marker and add an expression in the Expression box for a point marker.
    Once added, you can double click on the marker and change the label to (say) "ENOB: %E" to give it a more meaningful prompt.
    However, there's nothing to automatically add these as labels from the Spectrum Assistant (where you're computing those expressions currently). I believe there's an enhancement request asking for something similar though. Right now you have to add the markers manually yourself.
    Kind Regards,
