  3. How to implement and if statement in the calculator
  • Views 28432
LuisGutierrez
LuisGutierrez over 10 years ago
Hi all,
I am simulating a pre-regulator with an overvoltage reset and a deglitch filter. I use the function cross to determine when the output voltage crosses the reset value (both rising t1 and falling t2) and use this times to determine the violation time.
t1 = cross(VT("/vout") 8.6 1 "rising" nil nil)
t2 = cross(VT("/vout") 8.6 1 "falling" nil nil)
However, in some of my corner simulations either the rising/falling edge or both is not triggered by the cross function and it evaluates to nil, giving me an evaluation error later on. I wonder if there is a way to implement and if statement that determines that whether t1,2 equals "nil" and then overrides their value to some numerical value that I can use later on.
I suppose that is done via the calculator special functions using calCreateSpecialFunction and calRegisterSpecialFunction. However, the usage of these functions is not quite clear in the manual. Any input/example on how to do this is much appreciated.
Lucho.
  • LuisGutierrez
    Hi all,
    I managed to solve the issue by implementing the if statements within the expression as follows:
    if(cross(VT("/vout") 8.6 1 "rising" nil nil) == nil then t1=1 else t1=cross(VT("/vout") 8.6 1 "rising" nil nil))
    With this, if the expression evaluates to nil I assign my desired value there. If it passes normally, I get the result of the cross calculation. This ain't the most elegant way but for now it does the trick. I'm still interested in how to implement this in a custom function. I can't seem to be pass the arguments to the function properly; i.e. how to run the if with a value coming from the stack ?
    Bonus track: How to delete previously loaded functions via calRegisterSpecialFunction?
    Best regards,
    Lucho.
    Lucho,
    I don't believe there is a way of doing this. However, since quitting virtuoso and re-starting will remove the registered functions anyway (unless  you're calling calRegisterSpecialFunction in the .cdsinit), there's not really a big need for an unregister function...
