  3. verilogA model en operating point output
  • Views 15143
fabriceBG
fabriceBG over 10 years ago
I 've developped a verligA compact model with some specifica operating points (parameters calculted within the verilogA code). I can display them on the symbol thanks to dedicated setting in the CDF.
Now i would to work only in batch and I am looking for a solution to get those value diorectly for the netlist. I try to used spectre statment "save instace;oppoints" but it is not working.
Do I need to declare the oppoint paraleters like this in the va code
(* units=X, desc="this is my OP point description" *) real oppointName;
Is someone can help me.
regards,
Fabrice
    Fabrice,
    The syntax is:
    save instanceName:oppoint
    i.e. a colon, not a semi-colon.
    With this, you should get any variables in your Verilog-A view. It shouldn't be necessary to add any attributes to get them saved.
  • fabriceBG
    thanks Andrew
