  3. how to turn on direct text editing mode etc
  • Views 20490
RoseRope
RoseRope over 10 years ago
Hi Guys,
I had two question about the setting for schematic editor:
1) I would like to turn on direct text editing mode by default, what should be the scripts to add into .cdsinit?
2) How can I turn on the function: selection of device/object immediately after I press the command, such as copy/move etc, with the mouse hover on top of the object/device?
My cadence version is IC6.1.6-64b.500.11.EHF1535.
Billy
    To answer your questions:
    1. I'm not sure what you mean. You can direct edit the text either by hitting the T bindkey or double clicking the left mouse button over the text - no need to "turn it on by default".
    2. Do you mean infix? If so, it's:
      envSetVal("ui" "infix" 'boolean t)
  • RoseRope
    thanks so much for your quick reply!
    1) for the direct editing, I used to do double click and edit the text, but it doesn't work in my current version, I'm not sure what's going on: if the EDA disable it or sth, that's why I want to know if there is any variable to control it. I prefer to double click way though. The T binkey also doesn't work here :(
    2) that's what I want, thanks a lot!
    Best Regards,
    Yanjie
  • Tom Volden
    Tom Volden over 10 years ago
    Hi Yanjie,
    Bindkey T is set to schHiEditText() so you could add the following to your .cdsinit to restore that behavior:
    hiSetBindKey("Schematics" "None<Key>t" "schHiEditText()")
    TOM
  • RoseRope
    I see, thanks so much Tom! I'll try that.
    For the double click binding you'd need:
    hiSetBindKey("Schematics" "None<Btn1Down>(2)" "schHiDefaultAction()" )
    The schHiDefaultAction is a function that does a sensible operation on various objects - and when double clicking on a wire label, it performs the direct text edit.
  • RoseRope
    That's great! I'll add it those in.
    Thanks a lot Andrew!
