  3. Ocean parametric script - output analysis
  • Views 2015
VIPPER
VIPPER over 10 years ago
Hi
I have following Ocean script for parametric analysis. It was generated simply by ADE L by saving setup as Ocean script.
In this script I sweep delay_input parameter and my output is input_to_output_time. The output looks like sawtooth, but there is only one period. How can I find the minimum value of  input_to_output_time? I can only plot this but I have no idea how we can access this data via some commands.
simulator( 'spectre )
design( "/home2/ic_designs/ams/035/synopsys/mhl/Sim/A_tb/comparator_tb/adexl/results/data/.tmpADEDir_/TRAN_setup-time/A_tb_comparator_tb_schematic_spectre/netlist/netlist")
resultsDir( "/home2/ic_designs/ams/035/synopsys/mhl/Sim/A_tb/comparator_tb/adexl/results/data/Interactive.144/psf/TRAN_setup-time" )
modelFile(
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/cmos53.scs" "cmostm")
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/res.scs" "restm")
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/cap.scs" "captm")
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/bip.scs" "biptm")
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/ind.scs" "indtm")
'("/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/esddiode.scs" "esddiodetm")
definitionFile(
"/techfiles_ldap/ams/ams_v4.10/spectre/c35/soac/processOption.scs"
analysis('tran ?stop "VAR(\"simulation_end\")" ?errpreset "liberal" ?captab t )
desVar( "delay_input" 7.48n )
desVar( "vp" 1.8 )
desVar( "v_bg_lvl" 120m )
desVar( "clock_frequency" 75M )
desVar( "clock_period" "1/clock_frequency" )
desVar( "simulation_end" "2*clock_period" )
envOption(
'analysisOrder list("tran")
temp( 27 )
paramAnalysis("delay_input" ?values '(0 3e-9)
output_file = outfile("outputParam.txt" "a")
paramRun()
selectResult( 'tran )
outputs()
plot(getData("/clk") getData("/load") getData("/v_test_input") getData("/v_bg_lvl") getData("/I0/net04") getData("/I0/net014") )
input_to_output_time = delay(VT("/v_test_input") (VAR("v_bg_lvl") * 0.9) 1 "rising" VT("/load") (VAR("vp") * 0.9) 1 "rising" 0 0 nil nil)
plot( input_to_output_time ?expr '( "input_to_output_time" ) )
I have also one more question. How can I include above script into Ocean XL script generated to run across all corners? How can I combine parametric analysis with corner analysis?
Thanks and Best Regards
    You can use ymin(input_to_output_time) to find the minimum value. You could use ocnPrint or printf() to print it.
    You can't combine paramAnalysis into an OCEAN XL script; paramAnalysis is an ADE L feature only. You would be better off setting up the sweeps and corners in ADE XL and then exporting the OCEAN XL script - the sweeps and corners need to follow the ADE XL use model.
