  3. ADE L Design variables from include files
  • Views 16155
itos
itos over 10 years ago
I define lots of design variables. When I use "Copy from Cellview" in ADE L, all the undefined design variables are detected and I can fill them. I used this extensively.
Now I would like to generate them from a MATLAB script and created an scs file with "parameters Wn = 500u" statements (for example) and include it as library file.
But whatever I do, ADE L still thinks they are undefined, creates empty variables in the workspace. When netlisting, it either complains that they have been defined already or that they are undefined.
How to do this?
  • Tom Volden
    Tom Volden over 10 years ago
    You can prevent ADE from automatically copying the design variables from the cellview by setting the following in your .cdsenv file:
    asimenv.startup   copyDesignVarsFromCellview   boolean   nil
    Or equivalently in the .cdsinit file:
    envSetVal("asimenv.startup"  "copyDesignVarsFromCellview"  'boolean nil)
  • itos
    itos over 9 years ago
    Hi Tom,
    Thank you! However, for some reason this seems to be ignored. Are you sure this is true for ADE L too? I tried the .cdsinit and .cdsenv variant. If I enter the envSetVal in the CIW I get "t" (meaning success).
    I also want to emphasize that I generally like this copying feature. But for larger systems this gets somehow out of control.
    So I would like not only use this for MATLAB scripting but also to keep config for different blocks in a certain "state". For example, if I have an amplifier I do not want to set all the design variables in ADE L. Also, I do not want to statically fill the values in the array. Having include a "amplifier_config_v1764.scs" would it make easier to reference the config later in results for example.
