  3. combine libraries into categories
  • Views 18218
huadel
huadel over 10 years ago
I used to combine libraries under a category in cadence library manager using the command assign:
ASSIGN "category name" COMBINE lib1 lib2 lib3
I updated the cadence version to ICADV12.1-64b.500.8, this command doesn't work any longer, should I use a different command for this version ?
Hussein
    Hussein,
    I'm rather surprised if this was broken in a specific hotfix version, but I checked in the latest hotfix, ICADV12.1.500.15.2, and it works there.
    One point however - the second word on the ASSIGN library is not a "category name" - it has to be a library name that was defined using a DEFINE statement. Otherwise it won't do anything - this is the case in all versions.
  • huadel
    Thanks Andrew, defining the category name as a library was missing , it works now, Many thanks, Hussein
