  3. Parametric Analysis + IIP3 (pss/pac)
  • Views 3436
itos
itos over 10 years ago
I want to obtain IIP3 for different values of a design variable (e.g. a resistor) using parametric analysis. I successfully did this with a mixer and qpss/qpac.
I just had the following line in the ADE L Outputs window and swept the variable using parametric analysis:
ipnVRI((v("/vop" ?result "qpac") - v("/vom" ?result "qpac")) '(1 -2) '(-1 0) ?rport 50 ?epoint -80)
Now I want to do the same thing for an LNA (and hence use pac/pss) and suddenly it does not work any longer! :-( This is the line for the ADE L outputs:
ipnVRI((v("/vop" ?result "pac") - v("/vom" ?result "pac")) '-2 '0 ?rport 50.0 ?epoint -80)
But clicking on "Plot outputs" after the parametric analysis does not open a plot. I just says "Status: Evaluating" for a moment and then prints a single number (maybe the last result of the parametric analysis). No plot window opens, no message in the Log.
Is this a bug?
EDIT:
This is just CRAZY! I found out the bug and it's not about pss vs qpss. 2 Issues:
  1. A sweep within pss across Pin must be enabled. As a dirty hack, one must enable sweep, set number of steps to one and add the desired extrapolation point to "Add specific points"
  2. In PAC I had for the single frequency VAR("fin")+1M. Cadence dislikes that. So one must write e.g. 2001M. Similarly, refrain from putting a design variable into ipnVRI, e.g. ?epoint VAR("Pin"). Cadence will run crazy too.
However there is a new issue now: ipnVRI changes results significantly when chaning epoint whereas ipnVRICurves does not (as expected). Example:
ipnVRICurves((v("/vop" ?result "pac") - v("/vom" ?result "pac")) '-2 '0 ?rport 50 ?epoint -80)
ipnVRI((v("/vop" ?result "pac") - v("/vom" ?result "pac")) '-2 '0 ?rport 50 ?epoint -80)
both give me 2.85643 dBm. However, changing to
ipnVRICurves((v("/vop" ?result "pac") - v("/vom" ?result "pac")) '-2 '0 ?rport 50 ?epoint -60)
ipnVRI((v("/vop" ?result "pac") - v("/vom" ?result "pac")) '-2 '0 ?rport 50 ?epoint -60)
the first one gives me 2.8568 whereas the second one gives me 6.5767 dBm! Any idea how to fix that?
  • Tawna
    Tawna over 10 years ago
    Hi Itos
    What version of virtuoso and MMSIM are you using?   The following commands will give that information:
    spectre -W
    virtuoso -W
    Are you using Shooting Newton or Harmonic Balance?
    Are you getting any errors/warnings/messages in the CDS.log or spectre.out file?
    It's difficult what to say what the issue could be without more information.  You may want to contact Customer Support http://support.cadence.com for assistance.
    best regards,
    Tawna
  • itos
    Hi Tawna,
    Thank you! We just had a race condition ;-) (I edited my post with a solution while you were answering).
    $ spectre -W
    sub-version  13.1.0.186.isr5
    $ virtuoso -W
    sub-version  IC6.1.6-64b.500.11
    I tried both (hb and Newton), no messages in either (simulations run successfully). But as mentioned, there seems to be a bug which can be worked around by doing what I described.
    However, maybe you have an idea about the discrepancies between ipnVRI and ipnVRICurves?
  • Tawna
    Hi Itos, can you contact Cadence Customer Support with this question? I don't have time to set up a testcase and test this out right now. best regards, Tawna
