  3. Setting port order of symbol view using SKILL
  • Views 19088
Sheppy
Sheppy over 10 years ago
Is it possible to set the port order of a symbol view using SKILL?
Right now, every time ports get added, I have to go into the symbol viewer and then menu Edit -> Properties -> Port Order to check/change the port order. I'd rather do it in batch for a whole lot of cells by using a SKILL script.
Thanks in advance.
Sjoerd
    Andrew Beckett over 10 years ago +1
    Hi Sjoerd, Most of the checks for portOrder inconsistencies are rather redundant nowadays in my opinion (I have a request to turn them all off) - but for now, the way to control this is to set the portOrder…
    Hi Sjoerd,
    Most of the checks for portOrder inconsistencies are rather redundant nowadays in my opinion (I have a request to turn them all off) - but for now, the way to control this is to set the portOrder cellView property.
    So:
    cv=dbOpenCellViewByType(lib cell view viewType "a")
    cv~>portOrder=list("a" "b" "c") ; whatever the list of port names is that you want.
    Or remove the property everywhere - that will also clean things up. Typically it's only used by the Verilog netlister anyway, and unless this is a leaf cell, there's no particular need to control the order.
  • LDIL
    LDIL over 5 years ago in reply to Andrew Beckett
    Hi Andrew. Is this feature available?
    Andrew Beckett over 5 years ago in reply to LDIL
    See https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20370325
