  3. Error about extract CDF Parameters of CMOS into Layout
  • Views 14976
NGO TAN BINH
NGO TAN BINH over 10 years ago
Hi all
I encountered an error as follow: I divided N-MOS into multipliers ( for example: W=1u, L= 180n and multipliers = 4) but when i turned it into Layout XL, it only displays one N-MOS having W=1u and L = 180n but no additional ones.
I am using IC 615, TSMC 180nm Analog/mix signal Lib
Who can help me with this problem?
Thanks very much
Bình.
    Check on the VLS XL Options form to see if you have the m-factor parameters set up correctly.
