  3. Not able to interface spectre data with Matlab
  • Replies 8
  • Subscribers 137
  • Views 19811
Abhishek D
Abhishek D over 11 years ago
Hi All,
             I am facing this issue for some time now. Following the the snippet of the problem.
dir2='/home/abhishek/simulation/rc/spectre/schematic/psf'
dir2 =
data_list=cds_srr(dir2)
Error: License for the SpectreRF option could not be obtained.
??? One or more output arguments not assigned during call to "cds_innersrr".
Error in ==> cds_srr at 16
    sig = cds_innersrr(dirname);
As far as  I know I am able to run normal ADE-L transient simulation. Does SpectreRF requires additional license? I have gone through various entries on this forum . I tried to do the solutions but It didn't help.
Other information is as follows :-
1) Transient results are in psf format.
2) Also checked cds_srr function also it is there at the concerned location.
3) Typing cds_srr only doesn't give any error in matlab command prompt.
4) Matlab- R2008a
5) mmsim- 12.1.0.347.isr3
.bashrc entries are as follows :-
export MATLAB_PATH=/home/abhishek/MATLAB/
export LD_LIBRARY_PATH=`cds_root spectre`/tools/lib/64bit:`cds_root spectre`/tools/dfII/bin/64bit:$MATLAB_PATH/bin/glnxa64:${LD_LIBRARY_PATH}
export MATLABPATH=`cds_root spectre`/tools/spectre/matlab/64bit:${MATLAB_PATH}
export PATH=$PATH:$MATLAB_PATH/bin
Kindly let me know where I am making the mistake.
Best Regards
Abhishek
    Abhishek,
    The error message is a hangover from the original implementation of the Spectre Toolbox for Matlab. It was originally developed by the SpectreRF team, and was the "SpectreRF Toolbox" because it had a number of RF-specific m files in the toolbox for measuring common RF metrics from SpectreRF simulation results.
    At that time, it took 2 MMSIM tokens, or used a SpectreRF license.
    In MMSIM7.2 (ISR4) it was changed to only need a Spectre license or a single MMSIM token. However, the error message still mentions the SpectreRF option (I just reproduced this even in MMSIM15.1).
    All it means is that you can't get a license. Do you have $CDS_LIC_FILE (or maybe $LM_LICENSE_FILE) set to point to your license server?
    Either that, or all the licenses are in use.
  • Abhishek D
    Thanks Andrew for the information.
    "Do you have $CDS_LIC_FILE (or maybe $LM_LICENSE_FILE) set to point to your license server?"
    Yes. it is done propelry.
    is it possible to use standalone matlab without invoking ADE_L and then doing the post processing?  In that case, license will not be in use right? Can you suggest what should I do to make to working?
    Best Regards
    Abhishek
    Abhishek,
    I assumed you already where using matlab standalone. It doesn't really matter whether you do it with matlab standalone or from a Matlab measurement in ADE XL (not sure that's what you were doing either) - it's the simulation license that matters, not the ADE license.
    There's some license debugging that could be done - but for that you should contact customer support.
  • RaffaeleCapoccia
    RaffaeleCapoccia over 9 years ago
    Dear all,
    I am currently facing the same issue in interfacing SPECTRE with MATLAB using the SPECTRE/RF MATLAB Toolbox.
    The error is
    I checked the environmental variables definition as suggested but there is still some problem.
    Raffaele
    Which version of MMSIM are you using (the version of spectre) - that you're getting the toolbox from?
  • RaffaeleCapoccia
    Hello Andrew,
    I am using MMSIM version 13.11.355.
    Raffaele
    Hi Raffaele,
    OK, not the most recent, but should work.
    I just checked and the way I could get this error is if I don't have $CDS_LIC_FILE set (or $LM_LICENSE_FILE) to point to my Cadence license server before I start Matlab. You need the licensing set up the same way that you would if you were running spectre, for example.
  • RaffaeleCapoccia
    Thank you very much. Problem solved following your indication.
    Raffaele
