  3. CDL generation with command si: how to specify a path instead...
  • Views 4671
CDL generation with command si: how to specify a path instead of "netlist" for the resultFile ?
samung
samung over 10 years ago
hello,
doing the CDL netlist generation from an open access cell schematics I encounter an issue.
I would like to know if it's possible to specify a path, such as toto/titi/cell.cdl as the resultFile of the command:
si -cdslib pathToCdsLib/cds.lib -batch -command $resultFile
In my runDir, I have the cds.lib and the si.env
  • The si commands generates a netlist, in case I have the following setting:
si -cdslib pathToCdsLib/cds.lib -batch -command netlist
si.env:
hnlNetlistFileName = "netlist"
  • If I switch to the below setting:
si -cdslib pathToCdsLib/cds.lib -batch -command toto/titi/cell.cdl
si.env:
hnlNetlistFileName = "toto/titi/cell.cdl"
I have:
*Error* lineread/read: syntax error encountered in input at line 1 column 2 in file *stdin*
Thanks a lot for any help !!
P.
NB:
tool version:
UNIOPUS/uniopus_oa/cadence_amsams2010.2c_mmsim/lnx/tools/dfII/bin/32bit
    The argument after -command is a command not the name of the file. So when you do -command netlist you are telling it to produce a netlist.
    So when you give a filename after -command, it produces a SKILL error, because it's an invalid command.
  • samung
    Thanks Andrew !!
