  3. saving all nodes warning
  • Subscribers 133
  • Views 14921
PirateKing2008
PirateKing2008 over 10 years ago
Hi
To stop designers filling up the disks when they run corners because they forgot they had saved all nodes when debugging in the Test Editor, can there be a warning box that comes up when clicking run on corner sims? Just like the warning you get if about to run more than 100 corners/sweeps. I use the trick below so I can visually see in ADEXL by the state of a variable that I have saved all nodes and I can quickly turn them off without opening the Test Editor which is neat but a warning would be very useful too.
community.cadence.com/.../29306
  • skillUser
    skillUser over 10 years ago
    Lance - you should file a service request with Cadence to request this. That's the best way to make sure that the request is seen by someone at Cadence, rather than expecting someone in Cadence to take the time to look at this forum and then file the request on your behalf. Make it official! Regards, Lawrence.
