  3. Simulate the power conversion efficiency of a RF-DC rec...
  • Views 14790
Simulate the power conversion efficiency of a RF-DC rectifier
MenghanSun
MenghanSun over 10 years ago
Dear all,
I am trying to simulate the power conversion efficiency of a RF-DC rectifier, the power harvester used in UHF RFID tag. The structure of the rectifier is typically something like a dickson charge pump.
So, the antenna picks up the EM wave, convert it to voltage, feed it into the rectifier, and the rectifier convert it into DC to a resistive output load.
To model the antenna, should I use a port element, or ideal voltage source? I wish to do an input power sweep, with the ideal voltage, I can only sweep the input voltage.
Any help is greatly appreciated,
thanks,
Cheers,
Menghan
