  3. LEF file generation problem
  • Views 15177
Identical
Identical over 10 years ago
I keep getting a
macro cell_name has no terminals warning when I try to generate the LEF file. I opened the generated LEF file and there is no pin information for any of the cells
I checked the layout and it does have proper terminals.
    Either use the abstract generator or contact customer support since you've not really given enough information to allow anyone to work out what the problem is. With customer support we could look at your data together to understand the problem.
