  3. 'layerHeader in update mode' assura error
  • Views 1133
loboveena
loboveena over 10 years ago
Hi
I get the following error while running Assura DRC ; Can you help me understand what this error means and how do I fix this ?
Assura version used : 4.1_USR4_HF24
Finished output post-processing
cpu: 0.14  elap: 0  pf: 0  in: 32  out: 440  virt: 135M  phys: 684M
*ERROR* layerHeader in update mode: group 754, layer 262043
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
Veena
    Hi Veena,
    Please contact customer support. I can only find references to this error in very old versions of Assura (long before the one that  you're using) and those were supposedly fixed - so it must be due to something else.
    Kind Regards,
  • loboveena
    Can you atleast give me a hint regarding what this error means ?
    Veena
    Hi Veena,
    The internal CCRs covering this don't really give any details - and they were fixed something like 7 years ago.
    So there's not much I can help you with here - which is why I suggested contacting customer support. Presumably you have something that reproduces the problem.
