  3. models library setup
  • Views 19652
Kinneret
Kinneret over 10 years ago
hi,
 when i changing the simulator (in ADE L setup->choosing simulator)
i don't see the models.(in models library setup).
Would you please give me some clues to resolve this issue?
    Some questions since you didn't give much background:
    • Are the models filled in when you start ADE (not from loading a state)?
    • Are they set for a particular simulator (e.g. spectre, if that's the default)?
    • What simulator are you changing it to?
    • Do the model definitions reappear when you change back to the default simulator (spectre)?
    My guess (reading between the lines) is that you have a PDK or cdsenv setting which is defining the models for one simulator (e.g. spectre), but that's not happened for whatever other simulator you're switching to.
    Look at:
    envGetVal("spectre.envOpts" "modelFiles")
    It might have been done using asiSetEnvOptionVal (some PDKs do that), but the envGetVal should return the settings. You can try the similar envGetVal for the other simulator you're using.
