  3. How to open a new library/cell (add library into cds.lib...
  • Subscribers 133
  • Views 6346
How to open a new library/cell (add library into cds.lib) when already has been open a layout ?
Charley Chen
Charley Chen over 10 years ago
Dear All,
 In IC 6.1.6 ISR11/ISR12 , when already has been open a layout  , need to add a new library/cell to reference , so i add library into cds.lib ,
though library manager can show the library/cell , but when open it , it will pop  "Library Update" dialog ,
close  it , and nothing to do.
If need to close data and then open library/cell (it silimar to launch virtuoso again) , it is very not convient , especially for large layout .
Is there a right way to do ?
Thank you,
Charley
    Charley,
    Do you just need to call ddUpdateLibList() ? There should be no need to close data.
  • Charley Chen
    Andrew,
    It seems needs to be close data or launch again.
    From AE , he said that   "if one lib is marked for deletion and a cellview of this lib is opened in memory."
    Thank you,
    Charley
    Charley,
    That should only be necessary if you're deleting a library from the cds.lib, not adding a new entry. Maybe you omitted some relevant information from your question?
    Even then, you only need to close data from that library, not everything...
  • Charley Chen
    Andrew,
    I post the question from layout engineer's request. Maybe i lost some information.
    Layout engineer  usually include other cds.lib in his cds.lib , so the library maybe changed but he does not know ,
    Maybe that's why .
    Thank you,
    Charley
