  3. Transient-Noise Analysis, problem with multiple run mod...
  • Views 16583
Transient-Noise Analysis, problem with multiple run mode
Amir0098
Amir0098 over 10 years ago
Hello every body
I am pretty new in using OCEAN script and it would be great if someone help me with my problem:
I am running transient-noise analysis and I want to do multiple run to check my circuit in different noise conditions and understand the probability of the error in my circuit. The problem is that when I am running simulation in multiple run mode, previously perfect functions like 'Value' return 'waveform object' like srrWave XXXX (when I print the result in a file using fprintf) instead of for example a voltage in a specific time. What do I need is to have an specific number as an output for my 'Value function'. Then I am able to compare the influence of noise in different iterations. Can anyone help me in this regard?
in1=value(v("/in1" ?result "sweep_tran-sweep"),"Iteration" 6.0) t )
(The Cadence Version I am using is IC6.1.4)
Thank you so much in advance,
Amir
    If you want a single number, you'd need to specify the time you wish to get the value for. You're expression doesn't make sense as it has an extra t ) on the end for some reason. You'd need to do this kind of thing:
    ocnPrint(value(v("/in1" ?result "tran") 150u)) ; 150u is the time I want to look at.
    This will print the value of the voltage at that time for all iterations. Note I'm using the "aliased" name for the results (the results browser in newer versions of the IC tools shows the aliased name, which is more portable - you're using a long unsupported version of the tools) - so ?result "tran". You can do that too...
    Now, if you want to get the value for a particular iteration too, you could either do:
    in1=value(value(v("/in1" ?result "tran") "Iteration" 6) 150u)
    or you could swap the two value calls around:
    in1=value(value(v("/in1" ?result "tran") 150u) 6) ; could put "Iteration" before the 6 too.
    The waveform is structured with the time being the inner axis, so by default value operates on the inner axis each time - so in the second statement above, the 150u slices the values at that time leaving a waveform of the values at that time versus iteration, and then the second value call picks out the value at that iteration number (since that's now the inner axis).
    Hope that helps,
  • Amir0098
    Thank you so much Andrew for your response. Your suggestions worked out for me and I got my desire result. I really appreciate your active participation in the forum.
    Kind regards,
    Amir
