  3. Verilog-A 2**integer yields wrong value
  • Views 4818
AlbertoGS
AlbertoGS over 10 years ago
I have come across a very strange bug. I created a module in verilog-A that at some point converts a integer input into a binary number. To do so it successively divides the input by factors of 2
However, I found that using an expression of type:
2**i // i declared an integer
Does not result in the right number being generated!
Look at the following for loop
        for (i=`NUM_ADC_BITS-1; i>=0; i=i-1 ) begin
            $display("%d", 2**i);
        end
It ouputs:
2048
1024
511
255
127
63
32
15
8
4
2
1
Using a genvar or the function pow() solves the problem, however this behaviour seems to be potentially very dangerous to me. Does anyone have any insight of why this (should) happen?
Many thanks,
Alberto Gomez
    Hi Alberto,
    There's no good reason for this - it's a bug in the implementation as far as I can see. The ** operator was added in MMSIM13.1 (it was something introduced in the 2.3 VerilogAMS LRM).
    I've filed CCR 1526534 to get this fixed. You get slightly different behaviour depending on whether you're running 32 bit or 64 bit spectre (your output matches what I see in 64 bit spectre, whereas with with 32 bit spectre only 31 is wrong).
    I would suggest using 1<<i instead as that always works to get a power of 2 for integers (it does a 1 left-shifted i times) in the meantime.
