  3. Run RCX Problems
  • Views 15450
Run RCX Problems
rafaelon
rafaelon over 10 years ago
Hi friends from Cadence,
We use the following versions: virtuoso: IC6.1.5.500.16.2  and assura 4.1_USR3;
When we run QRC, occur two errors and some warnings. The detailed log is the following:
Loading tech rule set file : /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/.assuraSetup/Assura/techRuleSets
avlck:   ERROR: The command /usr/cadence/installs/ASSURA41/share/oa/bin/sysname returned an error status:
                            unknown
avlck:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
avlck:          See the "OpenAccess Installation and Configuration Guide" before
avlck:          you complete the configuration step. This manual is included with
avlck:          the Cadence product documentation.
Checking out 1 license for Assura_RCX 3.10
Starting /usr/cadence/installs/ASSURA41/tools/assura/bin/rcxToDfII /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/AssuraERC/rcx.inversor_ERC.rsf -t -cdslib /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.5:IC6.1.5.500.14 12/27/2012 09:22 (vl-sfrh47) $
sub-version 4.1_USR3, integ signature 2012-12-27-0821
run on cadence from /export/vol1/cadence/installs/ASSURA41/tools.lnx86/assura/bin/32bit/rcxToDfII on Fri Jan 15 16:08:31 2016
*WARNING* COMBINE attribute library not defined
 library: 'analogLib' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'functional' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'sbaLib' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'ahdlLib' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'basic' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'sample' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'US_8ths' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'ieee' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'ambit' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'std' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'synopsys' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
 library: 'connectLib' file: '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/xc018_combine.lib', line: 22
Finished /usr/cadence/installs/ASSURA41/tools/assura/bin/rcxToDfII
Constructing the RCX run script
*** ASSURA capgen VERSION 3.2 Red Hat Linux release 7.2 (Enigma) - (07/07/2010-10:53)  ***
*       (c) Copyright 2016, Cadence Design Systems, Inc.         *
*             All rights reserved.                 *
*  This software is the confidential and proprietary information of  *
*  Cadence Design Systems, Inc. and may not be copied or reproduced  *
*   in whole or in part onto any medium without Cadence's express    *
*    prior written consent. Unpublished rights reserved under all    *
*         copyright laws of the United States.             *
*             Cadence Design Systems, Inc.             *
*            555 River Oaks Parkway                 *
*              San Jose, CA 95134                 *
capgen Capgen results will be written to directory: /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/AssuraERC/inversor_ERC
*ERROR* at "capgen": No -p2lvs file '/net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/.assuraSetup/Assura/../../.xkit/setup/xc018/cadence/QRC_assura/XC018_2113/QRC-Typ/p2lvsfile' (or '_p2lvsfile') can be found in technology directory. Need to have a p2lvs file ready and redo capgen initialization run in the techdir.
quitting.
Forking:  /usr/cadence/installs/ASSURA41/tools/assura/bin/32bit/capgen -techdir /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/.assuraSetup/Assura/../../.xkit/setup/xc018/cadence/QRC_assura/XC018_2113/QRC-Typ -lvs /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/AssuraERC/inversor_ERC.xcn -p2lvs /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/.assuraSetup/Assura/../../.xkit/setup/xc018/cadence/QRC_assura/XC018_2113/QRC-Typ/p2lvsfile -sw3d -encrypt -dsub ndiff_thin,pdiff_thin,ndiff_MV,pdiff_MV,pwitrm,nwtrm,dnwtrm,bulkRcx_thin,bulkRcx_MV -length_units meters -cap_unit 1.0 -cap_ground_layer bulkRcx_thin -blocking csf_met12:0.02,poly1,met1,met2 -blocking csf_met3:0.02,met2,met3 -blocking csf_met4:0.02,met3,met4 -blocking csf_met5:0.02,met4,met5 -blocking csf_mett:0.02,met5,mtop -blocking CAPM,met5,mtop -blocking CAPM2,met2,met3,met4 -blocking CAPM3,met2,met3,met4,met5 /net/nfs1.fee.unicamp.br/export/vol1/home/DSIF/rafaelon/xkit_teste/AssuraERC/inversor_ERC
*WARNING* Bad return status from RCX script generator. 0x100
Could you say what mean these errors, and how we could fix them.
Best regards,
Rafael Nunes
    There seem to be an awful lot of things that aren't configured correctly here - and you didn't mention which QRC version you're using (maybe you're running Assura RCX rather than QRC?). Anyway, please contact customer support or your support organisation (if a university, you might go through Europractice for example) because trying to figure out all the things that are wrong and how to fix them in an public forum isn't going to be very efficient.
