  3. Some parameters not appearing in "vsin" source from Ana...
  • Views 3744
Some parameters not appearing in "vsin" source from AnalogLib
jdp721
jdp721 over 10 years ago
Hi
I am instantiating "vsin" from analogLib, but it is not having the parameters like "pac Magnitude",.. etc. required for some analyses.
Attached is a screenshot of the "vsin" properties form.
Can you please tell what might be the reason?
    Look at Options->Tool Filter. I suspect you don't have "spectre" enabled for some reason (maybe  you've been using other simulators in your environment). The tool filter settings control the display of parameters relevant for your simulator. My guess is you might have hspiceD selected instead?
    Kind Regards,
  • jdp721
    Thank you Andrew...that was exactly the reason...please have my regards :)
