  3. spectre error (64bit/32bit) on linux
  • Views 5553
Karev11
Karev11 over 10 years ago
When I tried to run spectre sim, I had error messages as below:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
I then ran runSimulation file, error message is:
/tool/cbar/apps/cadenceMMSIM/12.11.164/tools/spectre/bin/64bit/spectre: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
ERROR: Cannot execute 'spectre input.scs +escchars +log ../psf/spectre.out +inter=mpsc +mpssession=spectre0_15953_1 -format psfbin -raw ../psf +lqtimeout 900 -maxw 5 -maxn 5'
I'm currently running on RHEL 5.8 (Tikanga), however, if I ran on RHEL6 (Santiago). It works fine.
I noticed in the error message 64bit spectre is being linked. Is that the reason for the errors I got?  We do have 32bit spectre available, is there any thing I need to set up to have either 32 or 64bit spectre works if I have to run it in RHEL 5.8 environment?
thanks,
Kev
    This looks as if you've not got one of the relevant shared libraries available on the machine.
    First of all, I assume you're running on a 64-bit OS. We don't support 32-bit OS for some time - and spectre pretty much requires you to be on a 64 bit OS for at least some parts of the flow. The actual simulator can be run as 32 bit (the default normally) or 64 bit - this is a tradeoff between performance and capacity. The 32 bit simulator will be slightly faster than the 64 bit, but can't access any more than about 3.7Gbytes of memory (it's faster because there is less memory accessed because the pointers are 4 bytes rather than 8 bytes).
    Which version is used may be controlled by the $CDS_AUTO_64BIT UNIX env var, or via a setting on the Setup->Environment form in ADE.
    Now for that missing shared library. On my RHEL5.5 system (so should be similar) I have both the 32 bit and 64 bit version of readline installed:
    UNIX$ rpm -q -f /usr/lib64/libreadline.so.5
    readline-5.1-3.el5
    So the package name is readline-5.1.3.el5 (there may be a newer version - the key thing is that the rpm is called "readline"). I suspect on your RHEL6 machine if you do:
    UNIX$ rpm -q readline
    readline-6.0-4.el6.x86_64
    readline-6.0-4.el6.i686
    (on my RHEL5 machine I don't get the different suffix for the two different versions, one 64 bit, one 32 bit).
    So I think you just need to get the missing RPM installed.
  • Karev11
    Thanks for the reply.
    I ran "echo $CDS_AUTO_64BIT" and it returns "CDS_AUTO_64BIT: undefined variable", I looked at Setup->Environment, Run with 64 bit binary is not checked.
    I'm using RHEL5,  64bit OS.  You're right, when I ran, "UNIX$ rpm -q -f /usr/lib64/libreadline.so.5", I got "readline-5.1-3.el5". (when I ran  UNIX$ rpm -q readline, I got  "readline-5.1-3.el5" twice) I was concerned about installing the package because this issue happens only to me, not other co-workers who's running from the same server (unless they all changed some settings which I doubt), also CAD ppl could get mad in case I messed up things..
    I nevertheless downloaded one from internet and ran it "rpm -ivh readline-5.1-3.el5.x86_64.rpm", but got warning of "readline-5.1-3.el5.x86_64.rpm: Header V3 DSA signature: NOKEY, key ID 82fd17b2" and error of "can't create transaction lock on /var/lib/rpm/__db.000"
    Could it be that some settings/env var got accidentally changed only on my side? I'm just guessing.
    thanks,
    Kevin
    If that environment variable isn't set - you should check the runSimulation script to see if it has -64 specified on the command line for spectre.
    I can't see how it would not find the libreadline.so.5 on the machine if it is present, unless $LD_LIBRARY_PATH is set to something strange and is omitting /lib - but then various things might fail in that case. Even then I think the wrapper takes care of it - so that works.
    Probably best if you contact customer support. Guesswork via the forum isn't a particularly effective way of diagnosing the problem! Us being able to look at the setup with you is much more likely to get to the bottom of it.
