  3. IIP3 for a mixer: shooting vs. hb
  • Replies 9
  • Views 20474
itos
itos over 10 years ago
Again I need to dig up this old topic on shooting/hb. I want to simulate IIP3 for a passive mixer (ideal current input, simple double-balanced passive current-mode mixer using MOS, ideal current sink (small resistance or TIA using ideal OTA). It's really frustrating because results are unpredictibale and jump around wildly although effectively there are no changes.
For example:
  • There is huge difference between hb and shooting engine in qpss although the IIP3 curves look OK (they just shift)
  • Adding a 1 F AC coupling capacitance (i.e., effectively NO cap!) lets IIP3 drop by up to 24dB. Again, curves look OK
The mixer switches are the only non-ideal thing in the setup so I tried:
  • Replacing the mixer by ideal switches and adding a non-linear resistance (using pvccs). Now the results are complete garbage (either the 3rd order has no slope of 3 but of 1 or the curves just jump around wildly). Clearly the results between hb and shooting are not consistent but I cannot trust them anyway
  • I though maybe it's the models of my 28nm process which can't deal with that. So I tried using a solid 180nm process. Now I do not even get the IIP curves correctly - for hb and shooting. For example, I get curves like:
How to deal with something like that?
Which parameters could I tweak?
And what is the right engine for a passive, current-mode switch (with rectangular LO)? hb or shooting? According to
community.cadence.com/.../tip-of-the-week-when-to-use-harmonic-balance-engine-vs-shooting-newton-engine
it should be hb but I am not sure since the LO is rectangular ...
  • Tawna
    Tawna over 10 years ago
    Please see this Article on Cadence Online Support:
    11454704
    (COS) Difficulties simulating IP3 on a switched-FET mixer
    And see this reference: LINFET: A BSIM Class FET Model with Smooth Derivatives at Vds=0
    by Lawrence F. Wagner, C. Michael Olsen. IBM Systems & Technology Group, Global Engineering Solutions.
    http://www.nsti.org/procs/Nanotech2007v3/7/W79.604
    This is a known limitation with BSIM models.
    It is strongly recommended that you use the PSP, BSIM6, or HiSIM2 models for this application, as they do not have the inherent limitation of the BSIM3/BSIM4 models.
    If you don't have access to support.cadence.com, let me know.
    best regards,
    Tawna
  • Tawna
    One more thing... Strongly nonlinear -> use pss shooting. However, I suspect what you are seeing is due to the models.
  • itos
    Hi Tawna, Thank you. Actually I was referred to that aleady. I forgot to tell that I am not using BSIM but UTSOI (based on PSP) so I should not suffer from that. (However, the other experiments I did in the 180nm use BSIM). In any case, shooting takes terribly long, hb is fast. Is it still recommended to use shooting here because of my rectangular LO, right?
  • itos
    Upon further investigation it seems to me that shooting is more trustworthy (unfortunately because it's terribly slow) and hb often produces garbage results. I base this conclusion on:
    1.) Adding an AC coupling cap (like 1F) between the ideal LNTA and the mixer changes IIP3 significantly (up to 24dB!!) although all common mode voltages are the same and there is no DC current. It should not change anything. Usually without cap, hb brings much better IIP3 than with cap. For shooting the result seems to be the same in both cases.
    2.) I check DC IIP3 by sweeping DC input and calculate IIP3 from the Taylor series coefficients of the DC output voltages. Now, using very low frequencies for qpss (like fLO=1kHz, f1=1100 Hz, f2=1090 Hz) with shooting approaches the DC result. However, qpss with hb is significantly lower (something like 30dB).
    From 1+2 it can be observed that hb is sometimes significantly above, sometimes significantly below shooting. For (1) I guess the "great looking IIP3 result" I get is just bogus :(
    Hence it seems I can't trust hb.
    Any further remark is much appreciated!
    Could you contact customer support? I think it would be best if we could see this so that we can either check whether your hb settings are appropriate, or see if there is a specific problem that needs fixing.
  • itos
    Hi Andrew, the problem is I am student and hence do not have access to the support. Life would be so easy with it I guess ;-)
    Hence I need to rely on public information and volunteers from forums. Let me take this opportunity to thank you so much for all the voluntary help you give in this forum and which help me already so much.
    As a reference to my previous post, this shows a plot of "DC"-IIP3 vs. common mode voltage of the mixer with small load resistance (of 1mOhm or so). It can be seen that qpss/shooting curves approach the one obtained using dc Analysis (and extracting Taylor series coefficients via derivatives). It can also be seen that the hb versions are far off:
    http://snag.gy/xSczk.jpg
    This curve shows IIP3 vs. frequency for shooting/hb:
    http://snag.gy/20yFX.jpg
    The variants for shooting are consistent (with and without ac coupling cap) and make more sense: Higher frequency -> lower IIP3.
    hb on the other hand are much smaller, and produce different results.
    There should be a way of you getting support. If you're under the Europractice scheme (mostly in Europe) you can go to Europractice for support, and if they need support in turn they come to us in the UK. For other University programmes it is done typically via the designated owner of the programme at that institution - often a Professor.
    There is some detail on the process here:
    Without seeing your actual design and simulation setup, I doubt we can do much more...
  • itos
    itos over 9 years ago
    best regards,
    Tawna
    Hi Tawna,
    I hope you are still reading this.
    Could I come back to this offer to get an account?
    Thank you so much!
  • Tawna
    Tawna over 9 years ago
    If you are a student, you should talk to your Department Chair to get access to Cadence Online Support. I"m not sure if you are in the US or Europe. Processes differ depending on your geographical area.
    best regards,
    Tawna
