  3. Cadence library and cell views
  • Views 21028
Pyroblast
Pyroblast over 10 years ago
Hi guys,
I have a question regarding the hierarchy of cells.
Image that you have a library and inside that library you have several cells in which, two or three, lets say, are like top cells and then you have a bunch of other cells that are inside (with their respective symbol) of the top cell, and inside of some of this cells you have other cells (don't forget, all of them inside the same library), that is: Cell1, Cell2, Cell3 are top cells. Then you have Cell 1.1, Cell 1.2, Cell3.1. So inside Cell 1 you have Cell 1.1 and 1.2 and inside of cell3 you have cell3.1 and so on.
By chance, Cadence has any tool to show you in some way (like a tree structure or just a file with some pointers/paths) which cell is the top and then their childs?
Regards.
    Yes. Several:
    • The schematic editor and layout editor both have Hierarchy->Tree commands to show a text report of the hierarchy
    • In the CIW there is Tools->Print Hierarchy Tree which is a "fast" hierarchy tree tool
    • This is the same as the standalone "fastTree" command that can be run from UNIX
    • The navigator assistant in the schematic editor and layout editor (Windows->Assistants->Navigator)
    • The hierarchy editor (open a "config" view for your design) - this is typically used when you want to configure which view is used for which cell or for each instance. There's a tree view in this tool.
    5 methods is hopefully enough...
    Note for each of these you have to start from a top cell and then have it expand the hierarchy. There's nothing that I'm aware of that will search to find cells which are not referenced by anything else (probably of limited usefulness and also would really need to search across all libraries which would be slow, potentially).
  • Pyroblast
    Hello Andrew. I want to thank you for the reply. It was a big help. I haven't noticed that there was a "Print Hierarchy Tree" option in the CIW window.
    By the way, can you recommend me any tutorial or anything that I could read to learn a bit more about the Cadence Software? I know it is a question a bit vague, but what I want to learn is how to use better the Cadence Software in general, the most used options. For example, printing the hierarchy tree is one of these things. Other might be when you are copying a cell from other library how to check if everything went well, if there are no errors and so. Do you understand what I mean? It is like a general knowledge with the software to help you administrate libraries, cells, do check, search for errors, etc.
    Thank you in advance.
    That's a pretty open-ended question. There's the documentation of course, looking at <ICinstDir>/tools/bin/cdnshelp. You might also want to look at and look at Resources->Rapid Adoption Kits->Custom IC and Signoff - there's a very large number of workshops and tutorials to help you get started in a lots of areas. Plus there are videos in the video library (also under Resources).
