  3. Virtuoso ADE L calculator - delay function - Variable value...
  • Views 5102
Virtuoso ADE L calculator - delay function - Variable value in threshold field
Manp
Manp over 10 years ago
I am simulating my design for a sweep in a range of different VDD values and I need to find the delay for a huge number of waveforms combined in a "family". now the problem here is to express the threshold value as a variable of the original signal.
For example, I add getData("/WWL" ?result "tran") as a family of waveforms in signal1. How can I tell the threshold field of signal1 that the threshold for each wave of the whole family is the 50% of the maximum value of each waveform???
  • Divy
    Divy over 10 years ago
    As you are varying the vdd values so it will be a variable for you so in threshold field you can use that variable 0.5*VAR("vdd").
  • Manp
    Thanks Divy for your reply. I did a parametric sweep with vdd as the variable. and I tried to use your method. But, it gives an error of :
    (\"*Error* asiGetDesignVarList: no applicable method for the class\" List ())
