  3. Static current calculation using Ocean script
  • Views 14580
saikatc
saikatc over 10 years ago
I am using ocean script to calculate static current. For that I intend to calculate the current drawn at Vin=0 and Vin = 300 mV.
I have written the following script for that.
i_stat = value(i("/P0/s" ?result "dc")@0m) +
            value(i("/P0/s" ?result "dc")@300m)
However, it is not able to return the current at 0 or 300. Whereas I am using the similar script for noise margin calculation and there I am able to get the value of Vout when Vin is V_ih and V_il.
Any suggestion will be highly appreciated.
Regards
Saikat Chatterjee
  • saikatc
    The issue is resolved. @ won't be used here.
    Saikat Chatterjee
