  3. Problem seeing the layout content of the instances
  • Views 15555
Neo2012
Neo2012 over 10 years ago
I'm no very professional in working with Cadence, but I've know the fundamentals. I am working with the 90nm technology but when I want to add a NMOS as top level a square can be seen with no label on it,( I've worked with 180nm tech too but it had label on Mos boxes like "NMOS" for example), and when I press SHIFT+F to see its content it goes invisible( I've check Options,Display, stop level = 32 too but didn't help) but by Descending thorough the instance, layout can be seen. I am working with IC 6.1.4. how should I do to see the instants content in top level?
    Please post some pictures so we can understand what you're talking about. This is very unclear.
  • Neo2012
    Thank you for response, I have problem attaching pictures! when I click on Insert/edit media a blank window pops out!
    I already have IT looking into why this is broken (I saw the same yesterday). In the meantime if this is urgent, you should contact
