  3. capgen error
  • Views 14672
capgen error
Jaganath
Jaganath over 10 years ago
I am facing some error while using QRC for extraction for UMC PDK. I am using a version of  assura 4.1_usr4 along with EXT14.2. But while doing Assura RCX capgen error is coming. I have tried with EXT15.1 also, but it results in same error. PVS15.1 is also installed.Please suggest me a solution for this capgen error. Which version of  ASSURA, EXT and PVS are compatible with each other. Thank you.
    Same error as what? This has zero information apart from a few version numbers - no indication of the error you're getting. There is NO chance anyone will be able to help you with so little information.
