  3. Corner Simulation in ADE XL
  • Views 16330
nbsingh
nbsingh over 10 years ago
I am trying to do the corner analysis using ADE XL but when I run the simulation,  status is displayed as running and it never gets finished. There is no error shown.
When I do the simulations in ADE L, the simulation ends successfully and the result gets displayed in waveform viewer but when I do the corner analysis, the simulation hangs up and never gets finished. Please help me by suggesting some solution.
P.S. There is no problem related to the disk space and license as we have adequate ADE XL licenses.
    If you do Right Mouse Button->Output Log over the running simulation do you get a log file? Similarly if you do a Right Mouse button over the little terminal icons in the Run assistant (left hand corner of the ADE XL window) do you get a job log that shows what is happening?
    Probably contacting customer support is your best bet because it's very hard (and not particularly fast) to diagnose a problem where there is little information as to what you're doing.
  • nbsingh
    Thank you Mr Andrew for your kind reply. When I click the right mouse button over running simulation, the option isn't highlighted so i can't select the Output Log option to check the output log file. Also the Terminal Icon shows nothing. I checked all these earlier. Please also suggest some other thing if you find I missed or did wrong during simulation. Thanks again for your kind help. . Regards, N B Singh
    I did make another suggestion - contact customer support. As I said, it's very hard to diagnose these kind of problems with little visibility of the problem.
