  3. Capacitance in "fN"
  • Views 3543
Capacitance in "fN"
BaaB
BaaB over 10 years ago
I've just seen this unit of capacitance in "fN". "f" stands for "femto" however, what is "N" here? Thanks for help!
    Huan Nguyen said:
    what is "N" here
    Where is "here"? I rather expect this is a typo rather than anything real. However, given that you give no reference to where  you've seen this unit of capacitance, it's rather hard to comment! My ESP circuit isn't functioning well today, unfortunately!
  • BaaB
    Thank you for the help! Actually, I took a snapshot of it after ploting DC operating point with variable but I couldn't attach it here. Not sure what is the problem with picture attachment. Here is the link: http://i.imgur.com/9Jcfhs6.png
    Which simulator version (appears at the top of the spectre log file) and what type of model is this that you're using? I just did a simple test using a bsim4 model using MMSIM14.1 (so not the absolute latest, but close enough) and got this:
    Note that the image upload on this site is currently broken - the supplier we use is investigating why.
    BTW, the image uploading problem should be fixed now.
