  3. simulator changing from spectre to ams
  • Views 17029
asetji
asetji over 10 years ago
I have access to two different linux machines where my  home folder is mapped via nfs. I am trying to simulate the same design on those two machines at the same time. The only difference is say, on one machine I am running a two tone test and on the other machine i am running a one tone test. The design I am simulating contains huge amount of parasitic components and when spectre runs, it generally consumes all the available RAM, thats why i am using two different machines instead of  using ADE-XL and running different tests in parallel.
The problem now is, say on one machine, my ADE L is open . Now, when on the second machine, I open ADE-L, it shows that the simulator is AMS instead of Spectre. If I try to load the saved spectre state, I get a warning message saying simulator is different and only common options will be loaded. Only way to fix it is to restart the virtuoso.
Is there any workaround or fix for this problem, OR a better way to run simulations on different machines.
BR
    I suspect that you've either got a cdsenv variable (in a .cdsenv file or set in a .cdsinit file) to set the default simulator to AMS somewhere, or you are opening the config and then hitting the ADE button in the hierarchy editor (this currently always opens ADE with the simulator as AMS).
    Your solution is to either change the simulator before loading the state in ADE (Setup->Simulator) - change it back to spectre and then load the state. That should work. The other alternative (if the state is stored as a cellView in the library) is to double click on the state cellView in the library manager and it will open it directly (with the simulator and design that was in use at the time the state was saved).
    I don't think this is anything to do with you using two different machines.
  • asetji
    Thanks Andrew, I am opening config and test bench schematic together and from test bench schematic i am launching ADE-L. I will try directly opening the state from cellView.
    You can still change the simulator once in ADE L - that ought to work regardless of where you launched ADE L from. Somehow your default simulator has got changed in that session - but you can easily change it within an active ADE session.
