  3. Loading and streaming custom Pcell issue.
  • Views 15654
Petya
Petya over 10 years ago
I'm developing a skill pcell, but have a problem with loading it. I use two files one that has all my procedures and another that has the pcDefinePcell. I load the procedures file in the libInit.il file, and then load the pcell which compiles without problems. The next time I open a new session though it gives an Pcell eval fail error:
*WARNING* (DB-270002): ("funcall" 0 t nil ("*Error* funcall: argument #1 should be a function object or name (type template = \"ug\")" nil))
Also if I load it locally streaming out works. But when I use the library I created to be common and used by other users as well it doesn't :(
I tried using Pcell IDE, but somehow its doesn't work for me. Any help will be appreciated.
Petya
  • skillUser
    skillUser over 10 years ago
    Hi Petya,
    You should only need to load the code with the pcDefinePCell statement if the parameters or their defaults change, otherwise you can just load the 'drawing code', provided that your code is structured something like the following:
    :: file to define the PCell ::
    let( (library cell pcellId)
      library="myLibName"
      cell="myCellName"
      unless(ddGetObj(library)
        error("Couldn't open library %L\n" library)
      pcellId = pcDefinePCell(
        list(ddGetObj(library) cell "layout" "maskLayout")
          (length   "10.0")
          (width    "10.0")
        ;; call PCell drawing code
        MYdrawPCell(pcCellView length width)
      ); pcDefinePCell
      dbSave(pcellId)
      dbClose(pcellId)
    ::  file to draw the PCell  ::
    procedure(MYdrawPCell(cv l w "dtt")
      ;; drawing code goes here
    Then each time you change the drawing code you only need to load that (in each new session, for example).  Within a session you might need to purge the PCell from virtual memory to be able to test new drawing code.  With the above separation of PCell definition and drawing code, you should only need to load the latter from a libInit.il file.
    I hope this helps you.
    Lawrence.
  • skillUser
    Also note that you can use the regular IDE with the drawing code separated out, you can interactively debug the code in a separate editable cellview window, as if you are "inside" the PCell. E.g. in my example I'd open a new layout in edit mode and call the function in the CIW: MYdrawPCell(geGetEditCellView() "100.0" "50.0")
  • Petya
    Hey Lawrence,
    Thank you for that! This is what I normally do, but nevertheless I found I'm stupid and had a global variable defined the same for two pcells procedures and that was causing the problem. Thank you!
    Petya
