  3. Can user assign filename to fsdb in Spectre simulation result...
  • Subscribers 133
  • Views 17996
Can user assign filename to fsdb in Spectre simulation result using Spectre command option
mctang
mctang over 10 years ago
Hi
I run Spectre simulation (spectreXPS) on spice netlist using batch mode, but simulation output "fsdb" is not fixed. Is there any way to assign filename to fsdb ?
ManChak
    Do you just mean being able to run "spectre -raw myresultsDir ..." ?
  • mctang
    I used the following command to run spectre on spice netlist. However, the fsdb filename is not fixed as <design>.fsdb, which is the default name in other simulators. Instead, spectre assigns  fsdb filename  based on simulation type (e.g. transient analysis). Does spectre allow user to predetermine fsdb file name ?
    spectre +aps +spice -format fsdb $cellname.sp -raw ./scratchdir/dynamic -stdout run_spectre.log
    ManChak
    This is a consequence of spectre supporting multiple named analyses of the same type. Each can have their own separate result database.
    So for example if my netlist looks like this:
    R1 (n1 n2) resistor r=1k
    C1 (n2 0) capacitor c=1p
    V1 (n1 0) vsource type=pulse val0=0 val1=2 rise=1n width=10n period=20n
    mytran tran stop=1u
    yourtran tran stop=2u
    And I run with -f fsdb (the netlist above is in spectre syntax - so you can see I have two differently named transient analyses), I get:
    UNIX> ls myresults.raw/
    logFile mytran.tran.fsdb yourtran.tran.fsdb
    The filename has the name of the analysis instance, the type of analysis (because there could be other types) and the format as part of the name. You can't change the name of the file to match the design unless the instance name of the analysis matches the design name.
    The reason for this is that each result directory is intended to be unique for the design. In fact if you don't specify the -raw argument, then the result directory name is named based on whatever the input file was called. So that's unique. Then there's the logFile which is an index of all the results - so you a waveform tool (such as ViVA) can know what the various results databases produced by the simulator were for the specific run.
  • mctang
    Thank you for your help.
    ManChak
