  3. How to set the optimum column width in ADE Results?
  • Views 14649
Magistus
Magistus over 10 years ago
please look at this picture. It shows a part of the results table in ADE XL.
The Output and the Nominal columns are too small. Is there a setting like "Use optimum column width"? Maybe a environment variable?
Thank you and kind regards,
Magistus ...
    Hi Magistus,
    Don't think there's an environment variable to control this. Assuming this is still bad in a recent version (e.g. IC616 ISR14 or IC617 ISR1), then please contact customer support so that we can file a CCR on your behalf.
