  3. How to fix warning from Spectre about a missing bulk-source...
  • Subscribers 137
  • Views 17541
How to fix warning from Spectre about a missing bulk-source and bulk-drain diode?
Bean Nakamura
Bean Nakamura over 10 years ago
Hello guys,
I ran a transient analysis on the attached circuit and Spectre gave the following warnings:-
Warning from spectre at time = 120.665 us during transient analysis `tran'.
WARNING (CMI-2151): M0.main: Missing bulk-drain diode would be forward biased.
Notice from spectre at time = 120.665 us during transient analysis `tran'.
M0.main: Missing bulk-drain diode returns to normal bias condition.
Further occurrences of this notice will be suppressed.
How do I fix this warning? What does the warning even mean? Will it effect my simulations?
The circuit was simulated using Silterra Technology.
Thanks!
  • rossco299
    rossco299 over 10 years ago
    Hi Mohd, I am receiving a similar error. Did you end up solving this issue? Thanks.
  • ImanKian
    ImanKian over 9 years ago
    Spectre(R) Circuit Simulator User Guide
    Product Version 5.0
    July 2002
    [page 259, First paragraph]
    Most p-n junctions in semiconductor models include both a resistive (the diode) and a capacitive (the junction capacitance) model. If the diode reverse saturation current is set to zero, the resistive part of the junction is turned off, and the Spectre simulator assumes that the resistive portion of the junction does not exist (but the junction capacitance may still be present). In this case, if the voltage across the missing diode is larger than 10 * Vt (where Vt is the thermal voltage), Spectre will issue a warning message telling you that the junction, which is missing, will be forward biased. A follow-up notice is issued if, and when, the device returns to a normal bias condition
  • taraRF
    taraRF over 9 years ago
    I have also this problem : missing bulk-source and bulk-drain diode.
    is this warning make all simulators give inaccurate results???
    is it important fix this warning???
    my transistors are rfnmos2v and rfpmos2v at 0.18um process and they are Deep N-Well. Deep N-Well allow me use bulk conecttion as a seperated terminal.
    the bulk-source voltage of my transistor are about 0.5v.
    Thanks alot.
